HP Photosmart 7520
Microsoft Windows 10 (32-bit)
My priinter continuously prints: CONNECT xmpp008.hpeprint.com: 80 HTTP/1.0
@Ireneeb
Reset the printer to factory settings.
Go to Setup > Tools > Restore factory defaults
Now, reconnect the printer to the network and check if this helps.
Let me know how it goes.
KUMAR0307
I am an HP Employee
5 REPLIES 5
@Ireneeb, Welcome to the HP Support Community! I’m here to help.
I understand the printer is printing unwanted pages. Let us try these steps:
Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Note: HP recommends connecting the printer directly to a wall outlet rather than a surge protector or a power strip.
If this does not help, unplug the power cable and hold the power button down for 10-15 seconds and release it. Power on the printer and check.
Run HP Print and Scan Doctor to diagnose and fix any driver issue
Click here to download the file. Once downloaded, make sure to run the file to start the installation and click on 'Fix printing'.
Hope this helps! Let me know how it goes.
Click on the YES button to reply that the response was helpful and/or to say “Thank You”.
Have a great day!
KUMAR0307
I am an HP Employee
Thank you for the response to my printer problem, but it did not solve the problem.  I have tried numerous times to follow your instructions, but to no avail.  A couple of times yesterday the printer went back to normal mode and I tried to use the HP Print and Scan program, but then it reverted back to continuous printing each time.  Do you have any other suggestions?
@Ireneeb
KUMAR0307
I am an HP Employee
Thank you for your help.  This last solution worked!  Your help was appreciated very much.
@Ireneeb
Glad to know that the issue is now resolved. Feel free to contact us with any concerns related to HP products.
Happy to help!
KUMAR0307
I am an HP Employee
