hp officejet 3835
Note from moderators: this message was originally posted in another topic, but it was moved to a new one to give more visibility for volunteers that help customers in the Community.
Original topic URL: Problem with the printer or Ink system - HP Support Community - 8265631
hp officejet 3835
5 REPLIES 5
Hi @hey0kay,
I'd like to help!
I understand you are receiving a Problem with the ink system error.
Please try the below suggestions:
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
 Try the steps in the document -Printhead errors
If the issue persists, I'd suggest you contact HP in your region regarding the service options for your printer
Have a great day!
Hello Jay,
Thank you for the suggestion. I have tried numerous times unfortunately it didn't work.
The printer has been unable to print anything for 6 months now. I really don't like throwing things away. It was working fine but one day it kept saying "HP INSTANT INK PROBLEM". I was enrolled on the instant ink but since I wasn't able to print anything, I decided no unsubscribe.
The inks are fairly new so it has a lot in it in colour, the black is pretty much full.
I have also gone through the virtual live chat and it's like talking to a wall.
Check error in a single cartridge mode-
Try the single-cartridge mode
The printer you own can work in single-cartridge mode, wherein the printer will be able to print with one cartridge in the printer. Which will help us identify if its a cartridge issue or a printhead issue
To try single-cartridge mode follow the below steps:
  • remove the black ink from the printer, leave the color in and try printing,
  • then remove the color ink, insert the black  in and try printing
Let me know how this goes!
Hello Jay,
Thank you again for getting back to me.
I tried as suggested but the "HP Instant Ink Problem" still occurs..
As this is a hardware issue, I'd suggest you contact HP support in your region regarding the service options for your printer
Follow the instructions below to reach them:
1) Click on this link - https://www.hp.com/us-en/contact-hp/ww-phone-assist.html
2) Select your product type below.
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Select the chat or get phone number options based on your preferences.
6)Fill the web-form and proceed further.
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile Name, you should see a little blue envelope, please click on it.
Have a great day!
