HP Officejet 5746
Mac OS X 10.10 Yosemite
Ok, so I'm have the problem where the printer doesn't seem to see that there is photo paper loaded.
I've watched both videos, used the HP photo paper that came with, changed the print settings to photo and 4x6, had the screen actually displaying that the phone paper was in there like the Forum response showed and still when I send the pic the printer stops and gives the Out of Paper error.  I've been doing this for easily 30 minutes trying different things over and over....it should not be this hard.  Open to new suggestion, I have tried all on the conversation string.  Thanks
@ViennaNeedsHelp
I would like to take a moment to thank you for posting on the HP Support Forums. I understand that you have an HP Officejet 5746 e-All-in-One Printer and it doesn't recognize the paper that's loaded in it. You have even tried changing the print settings, I appreciate the steps you have performed and have certainly done a good job.
I recommend you to perform the below steps to isolate the issue and arrive at a solution:
Please uninstall the printer drivers and then reinstall them again. To uninstall printer drivers please follow steps from this link: http://hp.care/2gPcp70
Later, please download and install the drivers from this link: http://hp.care/2gPbZxC
I sincerely hope this helps. Keep me posted about the results. Good luck! 🙂
4 REPLIES 4
@ViennaNeedsHelp
Uninstalled and reinstalled.  Not what I wanted to spend time doing but it worked!  First photo printed!  Thank-you
I have an officejet 5740 all-in-one. Suddenly the printer is not recognizing the paper. Keeps saying out of paper. I reloaded the paper. I turned off the power and restarted. This is a fairly new printer. Very frustrating.
Working with a Dell /microsoft computer.
Hello,
Thank you for posting in this thread. Unfortunately based on when the last response was made, I have closed this thread to help keep comments current and up to date. We recommend starting a new thread for your issue.
To be more helpful with your post, you can add key information if you desire:
1. Product Name and Number (please do not post Serial Number)
• Example: HP Pavilion DV2-1209AX or HP Deskjet 3000 Printer CH393A
2. Operating System installed (if applicable)
• Example: Windows XP, Windows Vista 32-bit, Windows 7 64-bit
3. Error message (if any)
• Example: ""Low disk space"" error in Windows
4. Any changes made to your system before the issue occurred
• Examples: Upgrading your Operating System or installing a new software; or installing new hardware like a printer, modem, or router.
If you have any other questions about forum posting, please feel free to send me a private message!
Thank you
I work on behalf of HP
