Hp ink tank wireless 419 printer
1 REPLY 1
Hi @Bharkavi,
I'd be happy to help you!
Yes, The HP Ink Tank Wireless 419 printer is compatible with specific HP ink bottles designed for use with HP Ink Tank and HP Smart Tank series printers. According to HP's official guidelines, the recommended ink bottles for the HP Ink Tank Wireless 419 are:
  • HP GT52 Cyan Original Ink Bottle
  • HP GT52 Magenta Original Ink Bottle
  • HP GT52 Yellow Original Ink Bottle
  • HP GT51 Black Original Ink Bottle
These are the appropriate ink bottles designed for optimal performance and compatibility with your HP Ink Tank Wireless 419 printer. Using the correct HP GT52 and GT51 ink bottles ensures the best print quality and helps maintain the printer’s reliability.
Hope this helps! Keep me posted for further assistance
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-
HP Community Moderator
