Microsoft Windows 10 (32-bit)
Hi tank light shows that cyan colour is not full but the tank is full
3 REPLIES 3
Hi @Aqsasohail,
Thank you for posting your query, I will be glad to assist you.
I understand you're experiencing an issue with your printer that shows one of the ink levels as not full even when it is full.
I apologize for any inconvenience this may have caused, I'm here to help you today.
Please follow the steps below to fix the issue.
A) Perform a power drain.
 1) Unplug the power cord from the printer & wall.
2) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
3) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
4) Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Power on the printer
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If you are seeing that message on the printer software, uninstall the printer software by following the steps from this link and restart the devices.
D) Install the printer software by clicking on the link again and let me know if that resolves the issue.
Note: Enable Bluetooth for an HP Smart app setup: Enable Bluetooth on your computer or mobile device so that HP Smart can detect the printer during the setup.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
Hi I follow the steps as you said but it still indicates that ink is not full
Hi @Aqsasohail,
I am sorry to hear that the above steps did not help much but i do appreciate your efforts in performing the troubleshooting steps.
As you have exhausted all the possible troubleshooting steps to fix it. We appreciate your understanding and patience.
I've sent you a private message with the instructions to get in touch with the HP phone support to assist you further. In order to access your private messages, Click the Private message icon on the upper right corner of your HP Community profile Next to your profile Name, you should see a little blue envelope, please click on it or simply click on this link
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
