Supply System Problem with my HP OfficeJet 8715. “There is a problem with the supply system. Try replacing the affected cartridge with a different, non-empty, cartridge.”
I just installed a brand new yellow cartridge and I’m getting this message.
1 REPLY 1
Hi @Music1962,
Thank you for posting your query, I will be glad to assist you.
I understand you're experiencing an issue with your printer that has a supply system error.
I apologize for any inconvenience this may have caused, I'm here to help you today.
Please follow the steps below to fix the issue.
A) Perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) Refer to the steps on this link to further troubleshoot.
D) If the issue still persists, refer to the steps on this link to restore factory defaults and let me know if that resolves the issue.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
