Windows 11 Support Center. -
- HP Community
- Printers
- Supply system problem replace Y cartridge
05-15-2024 01:45 PM
I have an Ovvice Jet Pro 9010e and need to replace the yellow cartridge. I am using the HP Instant Ink so I know that I have the correct cartridges (HP 962). I am getting an error that says "Supply System Problem Replace Y Cartridge." This is the first time that I need to replace an ink cartridge since I bought the printer. No matter what I do I can't fix the issue. I have tried to update the printer driver. I have tried to turn the printer off and unplug it to reset it. I have checked for printer updates. I cannot get in touch with HP Support to assist with this issue. Chat and Phone support are "unavailable at this time."
05-17-2024 06:41 AM
Hi @Cassiedel1996,
I'd be happy to help you!
If you have performed all the steps from this document and still getting cartridge errors, and if you are enrolled in the instant ink program, I would need a few details.
Since the instant ink account details are confidential, please send me the required information via private message.
I am sending you a private message with the information required. Please check the mailbox icon at the top-right corner of this screen.
Please check your Private message icon on the upper right corner of your HP Forums profile,
Next, to your profile Name, you should see a little blue envelope, please click on it.
I hope this helps resolve this issue completely,
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-Moderator
I am an HP Employee
