HP Officejet Pro 8600 Plus e-All-in-One Printer - N911g
Serial Number
[Personal Information Removed]
Product Number
CN579A
Followed all troubleshooting tips.
Need phone support for United States.  I get this message:
Sorry, I am unable to connect you with an agent due to some technical issue.
I’ll show you other helpfull support options.
Other options are looping me into processes already tried and failed.
@51KID
Hello,
If the problem persists following the steps suggested by @GOLD_MASTER, you may need some manual cleaning of the printheads of your printer.
To do so, you can follow the instructions of the following HP video: https://youtu.be/iTPASKLUzPc.
I propose this solution, because I see that you receive an error related to the inking system.
Don't hesitate to contact us in case of need.
Best regards,:Wink:
I'm not an HP employee. Did this message answer your question? Include it below as an Accept As Solution! Did you find this message useful?  Click on the thumbs up set to give a Compliment! Follow us on Facebook Assistance customers HP.
In this video, you will see how to manually clean a removable printhead on your HP printer. If your printer is out of warranty and does not print black or color ink or has been printing blank pages, consider cleaning the removable printhead by following the steps in this video. You should only ...
8 REPLIES 8
Hello @51KID .
What are the instructions you have already followed?
I am proudly Mexican, a Computer Systems Engineer and a community volunteer.
If you found the answer helpful and/or you want to say “thanks”? Click the “ Yes ” box below Did I help solve the problem? don´t forget to click “ Accept as a solution” , someone who has the same query may find this solution and be helped by it.
Turned on then off.  Ball test.  I haven't been into the EWS, or replaced all of the expensive ink cartridges.
@51KID Update the printer firmware:
https://ftp.hp.com/pub/softlib/software13/printers/ojp8600n911_2011A/OJP8600_N911g-n_2011A.exe
Eliminate the error by resetting the printer without the ink cartridges.
Open the door or access cover to the cartridges.
If the cart moves to the center of the printer, continue with these steps.
If the cart does not move toward the center of the printer, close the door or access cover. Disconnect the power cord from the printer and power supply, wait 60 seconds, and then reconnect the power cord to the printer and a wall outlet. Turn on the printer, and then continue with these steps.
Remove the cartridges.
With the printer turned on, disconnect the printer's power cord.
Disconnect the power cord from the power supply.
Wait 60 seconds.
Plug the power cord back into the wall outlet and printer.
NOTE: HP recommends that you plug the printer directly into a wall outlet.
Turn on the printer.
Reinsert the cartridges, and then close the door or access cover to the cartridges.
Follow the steps to align the printer if prompted.
@51KID
Hello,
Best regards,:Wink:
This did not work, but lead me to the actual problem... which is covered in the subsequent resolution posted after this.
Followed the video's instructions.  Now works normally.
I replaced all ink jets and cleaned heads. Get same message what now??
@51KID
Hello and thanks for your return,
In order to resolve this issue, please reset the printer as follows:
  1. On the front panel of the printer, click once on the location of the home (the home is inactive).
  2. Click once on the location of the back arrow (the arrow is inactive).
  3. Double-click on the location of the home (the home is inactive).
  4. A hidden menu will appear, click Service menu.
  5. Scroll down to Reset Menu, and validate with OK.
  6. Scroll down to Semi-Full reset, and validate with OK.
  7. The printer will shut down, please restart it.
  8. Please reconfigure the printer.
If the issue remains:
Unfortunately, this confirms a hardware problem with the printer.
I am very sorry for this bad experience.
I don't know if you already know this but you can Contact HP and ask for a solution for your problem.
Best regards,:Wink:
