HP Officejet Pro 8600 Plus e-All-in-One Printer - N911g
macOS 12.0 Monterey
Hello.  After replacing empty cartridges with authentic HP replacements I got this error and can't resolve it.  Restarted, reinserted cartridges, cleaned print head, updated firmware and none work.  Printer comes out of the error if the old cartridge is reinserted but won't print because it is depleted.  I thought it might be the new cartridge so I returned it and got another one.  But same error occurs.  Any advice would be much appreciated.  Thank you.
1 REPLY 1
Hi @Mike1376,
Welcome to the HP Support Community
I understand you are getting an error message "problem with the printer or ink system" on your HP Officejet Pro 8600 Plus E-All-In-One Printer. Not to worry I will help you to get a resolution to resolve the issue.
To assist better:
  • Are you using genuine HP ink cartridges?
  • Does the copy print out the same way?
  • Was there any recent update on the printer prior to the issue?
  • Was there any paper jam or carriage jam issue on the printer recently?
While you respond to that, Let's perform a power drain:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till warm-up period finishes and the printer is idle
Update the printer firmware
  • Click here to download and install the latest printer firmware from your product
  • Click here to know different methods of updating printer firmware.
If the issue persists, then please follow the steps mentioned in this document: HP OfficeJet Printers - 'Printer Failure' Error
If the issue still persists, I'm sending out a private message to assist you with the next course of action.
Please check your Private message icon on the upper right corner of your HP Community profile Next, to your profile Name, you should see a little blue envelope, please click on it or simply click on this link.
ANAND_ANDY
I am an HP Employee
