OfficeJet 6700 premium
The print had appears to be missing, not detected or incorrectly installed, but it is correct.
1 REPLY 1
Hi @SSL5
Welcome to the HP support community.
I understand that you are facing an issue with your printer, I am glad to assist you today.
Please try these steps :
Close the ink cartridge access door. Reconnect the power cord to the rear of the printer, and then check the control panel for the error message. Sometimes error messages persist after inserting the printhead. If the error message persists, repeat the steps to reseat the printhead up to three times.
You may also check this document, Click HERE
I hope this helps resolve this issue completely,
-Regards
Raj
HP Support
Raj2111
I am an HP Employee
