HP Officejet 6700 Premium e-All-in-One Printer - H711n
When I power on my printer it states there is a problem with the printer or ink system, it will not allow me to bypass it and I have tried all the ink cartridge troubleshooting tips and nothing has worked, can someone please assist.
1 REPLY 1
Hi @Kim311,
Welcome to the HP Support Community
I understand you are getting an error message  HP Officejet 6700 Premium E-All-In-One Printer - H711n Ink System Failure on your HP Printer. Not to worry I will help you to get a resolution to resolve the issue.
To assist better:
  • Are you using genuine HP ink cartridges?
  • Was there any recent update on the printer prior to the issue?
  • Was there any paper jam or carriage jam issue on the printer recently?
While you respond to that, Let's perform a power drain:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till warm-up period finishes and the printer is idle
Update the printer firmware
  • Click here to download and install the latest printer firmware from your product
  • Click here to know different methods of updating printer firmware.
If the issue persists, then please follow the steps mentioned in this document: HP OfficeJet Printers - Resolving 'Print System Problem', 'Problem with Ink System' Errors
HP Printers - An 'Ink System Failure' or 'System Supply Problem' Error Displays
A_Gayathri
HP Support Community Administrator.
