Windows 11 Support Center. -
- HP Community
- Printers
- Using less color ink as possible
01-14-2021
05:28 AM
- last edited on
07-13-2021
02:43 PM
by
RodrigoB
Product: Pavilion g7-1150us
Operating System: Microsoft Windows 7 (64-bit)
Which print option uses less of the color cartridges, "Black Ink only" OR "Grayscale Off". Is there any option that uses ONLY the black ink cartridge?
1 REPLY 1
01-14-2021 07:51 AM
- Black & White or Black Ink Only: The printer uses only the black ink cartridge to produce a black & white print out. Any colors present in an original document or photo are converted to black. Select this setting when you want to print only with the black ink cartridge.
- Grayscale: The printer uses a mix of color inks to produce a high quality black printout. Select this setting when you want high quality black & white documents or photos.
Ask the community
