Windows 11 Support Center. -
- HP Community
- Printers
- envy 6555e printer will not print using usb, stated printer ...
06-12-2025 10:42 AM
@monk55, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
If your HP ENVY 6455e All-in-One Printer is not printing using a USB connection, follow these steps to troubleshoot the issue:
Check Error Messages:
- Look for any error messages on the printer display and resolve them by following the instructions provided.
Disconnect and Reconnect USB Cable:
- Ensure the USB cable is firmly connected to both the printer and the computer.
- Disconnect the USB cable and then reconnect it to the printer and computer.
Verify Printer Is Not Paused or Offline:
- Windows 10/8/7: Go to Control Panel > Devices and Printers.
- Windows Vista/XP: Go to Control Panel > Printers.
- Right-click your printer icon and select "See what's printing".
- On the Printer menu, make sure “Pause Printing” and “Use Printer Offline” are not checked.
- If any changes were made, try printing again.
Set Printer as Default Printer:
- Ensure your HP ENVY 6455e is set as the default printer (a check mark in a black or green circle next to it).
- If it's not the default, right-click and select "Set as Default Printer". Try printing again.
Restart the Print Spooler:
- Windows 10/8/7/Vista/XP: Go to Control Panel > Administrative Tools > Services.
- Right-click on “Print Spooler” and select “Properties”.
- Ensure Startup type is set to “Automatic”.
- Click “Start” if the service is not already running, and then click “OK”.
Clear the Print Queue:
- Windows 10/8/7/Vista/XP: Go to Devices and Printers.
- Double-click your printer icon to view the print queue.
- If there are documents in the queue, select “Cancel all documents” or “Purge Print Document” from the Printer menu and confirm.
- Restart your computer and then try printing again.
Check Power Connection and Reset the Printer:
- Ensure the power cord is firmly connected to the printer and the power outlet.
- Look for a green light indicating the printer is receiving power.
- With the printer turned on, disconnect the power cord from the back of the printer.
- Unplug the power cord from the outlet, wait 15 seconds, then reconnect the power cord and plug it into the outlet.
- Turn the printer on and try using it again.
I hope this helps.
Please feel free to reply here if you have any questions or if you need further clarification on any of the steps.
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
Garp_Senchau
I am an HP Employee
