hp officejet 7612
how to connect hp 7612 wireless printer when wireless communication is disabled. I have done everything. I cant change this setting to connect my printer to the new wireless router.
1 REPLY 1
@Keturah Use HP Print and Scan Doctor to check connectivity
Download HP Print and Scan Doctor.
  1. Run HPPSdr.exe from the download location on your computer.
  2. Once HP Print and Scan Doctor opens, click Start, and then select your printer.
    • If your printer in not in the list, turn it off and on, and then click Retry.
    • If there is a connection problem, follow the instructions in HP Print and Scan Doctor.
  3. If a screen prompts you to turn on printer updates, click Yes.
  4. If a screen prompts you to make your printer the default printer, click Yes.
  5. Try to print.
Assign manual IP address and that should fix the issue.
  • On the printer control panel, press the Wireless button . ...
  • Press the button next to Settings, scroll to Print Report, and then press OK.
  • Scroll to Configuration Page, and then press OK.
Setting a Static IP Address
Once you know your printer’s IP address, entering it is pretty easy. Here’s what you do:
HP Printer Static IP Address
  1. Run your Web browser.
  2. In the Web browser’s address bar, type the IP address of your printer and press Enter. Assuming you entered the right address, the HP printer control panel should appear.
  3. Click the Networking tab.
  4. Under Connections, click Wireless.
  5. Under IP Address Configuration, click Manual IP.
  6. Enter the IP address, subnet mask, and default gateway in the appropriate boxes.
  7. Click Apply.
You can refer this HP document for more assistance:- Click here
P.S: Welcome to HP Community 😉
Let me know how that pans out,
If you feel I was helpful, simply click on Accept as Solution to help the community grow,
That said, I will have someone follow-up on this to ensure you've been helped,
Just in case you don't get back to us,
have a good day, ahead.
Riddle_Decipher
I am an HP Employee
Learning is a journey, not a destination.
Let's keep asking questions and growing together.
