hp envy 4520
prints test page in color and printed on both sides of paper until I installed a new cartridge
1 REPLY 1
@resko480
Thank you for joining the HP Support Community
To provide you with an accurate solution, I'll need a few more details:
Is the copy working fine?
If the copy has the same issue follow the below instruction:
I suggest you do a Hard Reset
(1) Turn the printer on, if it is not already on.
(2) Wait until the printer is idle and silent before you continue.
(3) With the printer turned on, disconnect the power cord from the rear of the printer.
(4) Unplug the power cord from the wall outlet.
(5) Wait at least 60 seconds.
(6) Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
(7) Reconnect the power cord to the rear of the printer.
(8) Turn on the printer, if it does not automatically turn on.
The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Click on this link: https://support.hp.com/in-en/product/hp-envy-4520-all-in-one-printer-series/5447920/document/c047184... and follow the steps.
If the copy is working fine, Use HP Print and Scan Doctor.
HP Print and Scan Doctor is a free tool for Windows to help resolve common printing and scanning problems, such as missing or corrupt print drivers, connectivity issues, firewall issues, scan error messages, printer offline, and print jobs stuck in the print queue.
Click on this link: https://support.hp.com/in-en/document/c03286146 to Download and run HP Print and Scan Doctor.
If the issue persists, I recommend you delete the driver at the root level and Install the drivers, follow the steps below:
Remove the USB if connected
1.) In Windows, search for and open Programs and features
2.) Select your HP Printer
3.) Select Uninstall
4.) In Windows, search for and open Devices and printers
5.) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose `Delete' or `Remove Device'
6.) Open up the run command with the "Windows key + R" key combo.
7.) Type printui.exe /s and click Ok. (Note: there is a space in between "printui.exe" and "/s")
8.) Click on the "Drivers" tab
9.) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10.) Select Ok
11.) Select Apply and Ok on the Print Server Properties windows
12.) Close Devices and Printers
Then, Click on this link: https://support.hp.com/in-en/drivers/selfservice/swdetails/hp-envy-4520-all-in-one-printer-series/54... to download and install the HP ENVY 4520 series Full Feature Software and Drivers.
Keep me posted, how it goes!
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Have a great day!
Cheers:)
Raj1788
I am an HP Employee
