Windows 11 Support Center. -
- HP Community
- Printers
- hp deskjet wont print when wireless. It says its offline
01-04-2018 11:30 AM
Hi Ive bought a hp deskjet 2630. Ive downloaded the software, followed all the instructions but it wont connect and print wirelessly. It works when i plug usb in but i want to use wirelessly. Ive gone through all the troubleshooting steps and the printer wont connect and says its offline. Its driving me up the wall so has anyone any ideas please?
Solved! Go to Solution.
01-05-2018 01:50 PM
Welcome to the HP Forums. I would be happy to help you with your HP Deskjet 2630 Printer. I understand that you are getting printer offline error and you have already done some preliminary troubleshooting.
However, I will need a few details to provide an accurate solution,
- When did this issue start?
- Did you do any hardware or software changes?
Meanwhile:
Use HP Print and Scan Doctor to check connectivity.
From the computer you are trying to print from, download and run HP Print and Scan Doctor. When this link is clicked, HP Print and Scan Doctor is downloaded using your Internet browser's download capabilities.
After opening Print and Scan Doctor, read and respond to the screens to resolve the problem.
Set the default printer and unpause printing
Turn the printer off and on, and then make sure it is in a ready state.
Search Windows for devices, and then click Devices and Printers in the list of results.
Find the icon for the printer you originally installed.
If a color or grey icon displays with a green checkmark, continue to the next step.
If a color or a grey icon displays without a green checkmark, right-click the icon, select Set as Default Printer, and then continue to the next step.
If one color and one grey icon displays for your printer, right-click the color icon, select Set as Default Printer, and then continue to the next step.
Figure : Changing the default printer from the gray (offline) printer icon to the colored (online) icon
Right-click the icon for the default printer, and then select See what's printing.
The print queue window opens.
Click Printer. If a checkmark displays next to Pause Printing and Use Printer Offline, click each item to remove the checkmark.
Figure : Example of the Pause and Use Printer Offline selections
Try to print.
Update the printer firmware
HP regularly releases printer updates. Updating the printer firmware might resolve the issue. For more information, see Updating Firmware on the Printer.
Create a manual connection
Print a Network Configuration Report or Wireless Test Report from your printer.
If your printer has a control panel with a display, print the report from the network settings or network setup menu.
If your printer does not have a display, print the report using the buttons on the printer control panel. For many HP printers, this is done by pressing and holding the cancel button or a combination of buttons on the control panel until a report prints. For more information on how to print a report for your printer model, see the User Guide or search the HP website for network configuration report and the model of your HP printer.
On the report printout, look at the network status for your network connection type (wired or wireless.)
Figure : Example of a correctly connected wireless network status
If status is connected, continue with these steps.
If status is anything other than connected, such as Off or Disabled, then the printer is disconnected from your network. This is the reason your printer is offline. You must connect the printer to your network before you continue. For more help on how to set up a connection to your network, see the User Guide, search the HP website for your printer model and wireless or wired network install, or use the wireless setup wizard from the control panel of your printer if available.
On the report, find the IP Address, subnet mask, and Default Gateway for your active (connected) network connection type. If your report has separate numbers for IPv4 and IPv6, then use the numbers listed in the IPv4 section.
From a computer connected to your network, find the URL(s) for Embedded Web Server (EWS) on the report and enter the URL into your Internet browser. If the webpage appears blank, use a different Internet browser.
Figure : Example of the URL for the EWS
Click the Network or Networking tab, and then open the section or page for your network type: wired or wireless.
Click Manual IP.
If you see a Suggest a Manual IP Address button, click Manual IP address, and the Manual IP addresses are automatically filled out for you.
If your page does not have a button to suggest a manual IP address, type the IP address, subnet mask, and default gateway using the numbers shown in the report you printed.
Figure : Example of setting up a Manual IP configuration
Write these new numbers on a piece of paper. You might need to use them later when adding a second printer device.
Click Apply, and then wait until the changes are confirmed.
Add a second printer device to Windows
Search Windows for devices, and then select Devices and Printers in the list of results.
Right-click the name of your printer, and then select Printer Properties.
The Properties window opens.
Click the Ports tab, and then click Add Port.
Select Standard TCP/IP Port, and then click New Port.
Figure : Creating a new TCP/IP Port
Type the printer’s IP address that you wrote down earlier, and then click Next.
Select the new Standard TCP/IP Port from the list, and then click OK.
NOTE:
You might see a second printer device display in the list of devices. Do not uninstall either printer device. Leave both printer devices.
Try printing.
Add the printer using HP Printer Assistant
From the Device and Printers window, right-click one of the HP printer icons, and then click Remove Device.
If a second printer icon is shown, right-click it, and then click Remove Device.
There should be no printer devices listed for your printer.
Open HP Printer Assistant. Search Windows for your printer name, and then click it in the list of results.
HP Printer Assistant opens.
Read and respond to the screens to add a new printer.
From the Devices and printers window, right-click the name of your printer, and then select Printer Properties.
Click the Ports tab, and then select the Standard Port you created earlier.
A second printer displays in the list of devices.
Try printing.
Click here and refer the document to perform the above steps.
Let me know how it goes.
Cheers.
Sandytechy20
I am an HP Employee
01-05-2018 01:50 PM
Meanwhile:
Try to print.
Click Manual IP.
NOTE:
Try printing.
Try printing.
Cheers.
Sandytechy20
I am an HP Employee
