Windows 11 Support Center. -
- HP Community
- Printers
- hp ink tank wireless 419 printer cartridge tricolor problem ...
1 REPLY 1
07-10-2024 06:51 AM
Hi @tech2019,
If your HP Ink Tank Wireless 419 printer is having issues with the tricolor cartridge, here are some steps you can take to troubleshoot and potentially resolve the problem.
- Check Cartridge Installation: Ensure that the tricolor cartridge is correctly installed in the printer. Open the printer cover, gently remove the cartridge, and then reinsert it firmly into its slot.
- Inspect Cartridge: Check the tricolor cartridge for any signs of damage or leaks. If you notice any, replace the cartridge with a new one.
- Clean Cartridge Contacts: Sometimes, dirt or debris on the cartridge contacts can cause issues. Turn off the printer, remove the tricolor cartridge, and gently wipe the contacts with a lint-free cloth or cotton swab lightly moistened with distilled water. Allow the cartridge contacts to dry completely before reinserting.
- Restart Printer: Turn off the printer, wait for about 30 seconds, and then turn it back on. Sometimes, a simple restart can resolve cartridge recognition issues.
- Update Printer Firmware: Check if there are any firmware updates available for your printer on the HP support website. Updating the firmware can sometimes fix bugs related to cartridge recognition.
- Reset Printer: If the above steps don't resolve the issue, try resetting the printer. This typically involves turning off the printer, unplugging it from the power source, waiting for a minute, and then plugging it back in. Turn on the printer and check if the problem persists.
- Replace Cartridge: If none of the above steps work, and if the cartridge is old or depleted, replace it with a new HP tricolor cartridge compatible with your printer model.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
Ask the community
