Windows 11 Support Center. -
- HP Community
- Printers
- hp laserjet pro m15w started blinking warning and power ligh...
02-05-2021 10:57 AM
Hp LaserJet Pro M15w production number w2g51-00907 started blinking both warning and power light after I tried to install new drivers from HP homepage download section. I´ve tried everything to get it work again but nothing works, I even tried the factory reset which I found on some forum, didn´t work. What I need to do to get it work again, is there some kind of code, I´ve read that some users had similar problem.
Solved! Go to Solution.
02-11-2021 01:14 PM
I reviewed your post and I understand that the print lights starting blinking when you installed a new driver.
Don’t worry, I assure you I will try my best to get this sorted.
I recommend you follow the steps in the below article and check if it helps.
Let me know how it goes and you have a great day!
P.S: Welcome to the HP Support Community 😊
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
Stay Home – Stay Safe
The_Fossette
I am an HP Employee
02-11-2021 01:14 PM
Cheers!
The_Fossette
I am an HP Employee
02-16-2021 06:25 AM
Perfect, I am really glad to hear that!
If any other questions arise, please feel free to write back to me.
Cheers!
The_Fossette
I am an HP Employee
