Windows 11 Support Center. -
- HP Community
- Printers
- hp officejet pro 8130e series printhead problem
1 REPLY 1
05-24-2025 03:16 AM
@maryport1, Welcome to HP Support Community.
If your HP OfficeJet Pro 8134e All-in-One Printer is showing a printhead problem despite being nearly new and lightly used, here are some steps you can take to troubleshoot the issue:
Restart the Printer
- Turn off the printer and unplug it from the power source.
- Wait for about 60 seconds.
- Plug it back in and turn it on.
Check the Ink Cartridges
- Open the printer and ensure all cartridges are properly seated.
- Remove and reinsert each cartridge to ensure good contact.
- Make sure you're using original HP cartridges—non-HP or refilled cartridges can cause issues.
Clean the Printhead Contacts
- Power off the printer and unplug it.
- Open the access door and gently remove the printhead.
- Use a lint-free cloth slightly dampened with distilled water to clean the copper-colored contacts on the printhead and inside the printer.
- Let everything dry for 10 minutes before reinserting.
Update Firmware
- Go to the HP Support page.
- Download and install the latest firmware and software updates.
Run HP Print and Scan Doctor
- Download the HP Print and Scan Doctor tool.
- It can automatically detect and fix many common printing issues.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
Ask the community
