ink system failure, then supply system, then continuous ink system, printer HP 8730 ran out of yellow ink that started all this, installed new cartridge and the fun has not stopped to make it work.
1 REPLY 1
@Oscar104
Let's try to reset the Printer here:
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Also, try connecting the Printer to a different wall outlet directly.
Also, try a firmware update: https://support.hp.com/in-en/document/c02919168
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
I am an HP Employee
