hp envy 4520
macOS 10.14 Mojave
my hp 4520 will print a document from my iPhone, but when I print from my Mac, it sounds like it's printing, but nothing prints on the paper. HELP!
1 REPLY 1
@MYRTLEBEACHGUY, Welcome to HP Support Community!
Ensure that the printer is up to date with its firmware and Mac is up to date with its software. If you are unsure you may use the links below to update the printer firmware and Mac software:
Update printer firmware
Update software on Mac
Remove and add the printer
Click the Apple menu, and then select System Preferences.
Depending on your operating system version, click Print & Fax, Print & Scan, or Printers & Scanners.
Click the name of your printer, click the Minus sign, and then delete the printer.
Select printer and click the minus sign
Click the Plus sign, and then click Add Printer or Scanner.
Click the Use or Print Using box, and then select AirPrint
Select AirPrint from the Use menu
Click Add to add the printer to the list.
Try to print.
Keep me posted for further assistance.
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
TEJ1602
I am an HP Employee
