Windows 11 Support Center. -
- HP Community
- Printers
- my HP 8610 printer will not power on
1 REPLY 1
07-16-2024 08:29 AM
Hi @Bonnie126,
If your HP Officejet Pro 8610 printer is not powering on, there are a few steps you can try to troubleshoot the issue.
- Check Power Connection: Ensure that the power cable is securely plugged into both the printer and the power outlet. Try plugging it into a different outlet to rule out any issues with the power source.
- Inspect Power Adapter: Verify that the power adapter (if your printer uses one) is properly connected and functioning. Sometimes adapters can develop faults.
- Reset Power: Disconnect the power cable from the printer and wait for about 30 seconds. Then, reconnect the power cable and try turning on the printer again.
- Check for Physical Damage: Inspect the printer for any physical damage, particularly around the power input area or internal components.
- Test with Different Cable/Adapter: If possible, try using a different power cable or adapter that is known to work properly with other devices.
These steps should help diagnose and potentially resolve the power issue with your HP Officejet Pro 8610 printer.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
Ask the community
