I have sone al;l suggested things and printer still will not print in color. All new cartridges. Have performed maintenance.  Does anyone have a customer service number for HP?
1 REPLY 1
Hi @jane1130,
If your HP OfficeJet Pro 6978 is not printing in color, there are several possible reasons for this issue. Here are some troubleshooting steps you can follow.
Check Ink Levels:
  • Ensure that there is sufficient ink in all the color cartridges. You can check the ink levels through the printer software or on the printer's control panel.
Color Printing Settings:
  • Make sure that your print settings are configured to print in color. When you go to print a document, check the printer settings to ensure that color printing is selected.
Printer Driver:
  • Verify that you have the latest and correct printer drivers installed on your computer. Outdated or corrupted drivers can cause printing issues.
Print Quality Settings:
  • Check the print quality settings in the printer properties. Sometimes, the print quality may be set to grayscale or black and white, which will result in monochrome printing.
Printer Software:
  • Ensure that the printer software on your computer is correctly installed. You may need to uninstall and reinstall the printer software to resolve any issues.
Paper Type:
  • Make sure that you are using the correct type of paper for color printing. Some printers may not print in color on certain types of paper.
Color Cartridge Issues:
  • If the color cartridges are old or have expired, they may not produce accurate colors. Consider replacing the color cartridges with new ones.
Clean Print Heads:
  • Use the printer's maintenance tools to clean the print heads. Unclean print heads can result in poor print quality.
Check for Updates:
  • Check for firmware updates for your printer. HP often releases updates to fix bugs and improve performance.
Test Print:
  • Print a test page from the printer itself. Most printers have a built-in function for this. If the test page prints in color, the issue may be with the computer or software settings.
Default Settings:
  • Ensure that color printing is set as the default option on your computer. This is especially important if you are printing from multiple devices.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
