Windows 11 Support Center. -
- HP Community
- Printers
- officejet pro 8020 won't print color
08-02-2023 08:32 PM
Hi @jvstrong,
I'd like to help!
Perform the following tasks in the order given. Use the printer after each task to see if the issue is resolved.
Clean the printhead
The printhead could be clogged, and you might need to clean the printhead several times to restore print quality. Use an automated tool from the printer control panel to clean the printhead.
CAUTION:
Never turn off the printer without ink cartridges installed. To avoid issues that require cleaning the printhead or that can damage the ink system, always replace ink cartridges as soon as possible, and always turn off the printer using the Power button.
On the printer control panel, open the Setup menu, and then touch Printer Maintenance or Tools.
Touch Clean Printhead, and then touch Continue.
After the cleaning completes, a Test Page prints.
Examine the Test Page.
If the print quality is unacceptable, touch Clean Again to continue the next level of cleaning. If necessary, repeat these steps for the third cleaning cycle.
NOTE:
If the printhead is badly clogged, it might require another cleaning cycle. If so, wait 30 minutes before you perform all three levels of cleaning again.
If the print quality is acceptable, touch Done.
Check for ink smears on the back of printouts
If there are smears of ink on the back of your printouts, use an automated tool to resolve the issue.
Touch Clean Page Smears or Clean Smear.
The printer feeds one page slowly. The printer might make some noise for approximately 1 minute.
Wait until the page is out of the printer before you remove it.
Make sure you are using the correct paper for your print job
Make sure the paper you are using matches the print job. If it is not, reload the printer with the correct paper type.
Load the paper print side down in the input tray. Many papers have printing and non-printing sides, such as photo paper and envelopes. Usually, the smoother side is the "print side," and sometimes, the non-print side has a logo of the paper manufacturer on it.
Do not use wrinkled or curled paper. Use only clean, wrinkle-free paper.
Use the correct paper type for your project.
For everyday text documents, plain paper with ColorLok technology works well. Paper with ColorLok technology is industry-standard paper that works well with HP ink.
For documents with dense printing, such as high-contrast graphics or photos, use HP Advanced Photo Paper for best results.
Some paper might not absorb ink as well as others. If your prints smear easily, make sure you are using a recommended paper.
Store photo paper in its original packaging inside a resealable plastic bag. Store the paper on a flat surface in a cool, dry place. Load 10-20 sheets of photo paper only when you are ready to print, and then put the unused paper back in the packaging.
Try using a different paper. This determines if the problem is related to the paper.
You may refer to this document for further assistance.
Hope this helps! Keep me posted for further assistance.
Nal_NR-Moderator
I am an HP Employee
08-02-2023 09:38 PM
Hi @jvstrong,
I'd like to help!
Clean the printhead
CAUTION:
NOTE:
Nal_NR-Moderator
I am an HP Employee
08-03-2023 07:41 AM
Hi @jvstrong
I see that you are facing cartridge issues with HP Printer.
To isolate the issue, I would request you to elaborate the defect you are referring to.
Meanwhile, you can perform the steps mentioned in this link.
I hope this helps.
Treeko
HP Support
I am an HP Employee
