Featured blog article:
A7F64A
printer won't print. new ink cartridges, but keeps going back to read old ink levels, message, "there is a problem with the printer or ink system. Turn printer off, the on. If problem percists, contact HP."  I have done all of that. I have taken the cartriged in/out, on/off, unplug/plug back in. removed the seating that the cartridges are in, replace it (careful not to touch the sensors). printer was back on line for a moment, ink levels were correct, printed one print job, then went back to the same error. nothing has worked to bring it back to working
1 REPLY 1
Hello,
Below listed are possible solutions to fix the Printhead problem error on your printer.
Solution one: Reset the printer
Solution two: Reseat the printhead
Solution three: Replace the printhead
Solution four: Service the printer
Use the below  support document that should guide you in performing above mentioned Solutions.
https://support.hp.com/in-en/document/c04100778
More info can be seen in this video - https://www.youtube.com/watch?v=tqX8GL1S_uw
If issue still persists its time to call HP Tech Support @  https://support.hp.com/us-en/contact-hp
Regards,
Jabzi
Give Kudos to say "thanks" by clicking on the "thumps Up icon" .
Click "Accept as Solution" if it solved your problem, so others can find it.
Although I am an HP employee, I am speaking for myself and not for HP.
