officejetpro 8720 problem with suppl
1 REPLY 1
Hi @mac226,
Welcome to The HP Support Community.
I understand issues with the supply system on an HP OfficeJet Pro 8720 could indicate a problem related to ink cartridges, the printhead, or internal mechanisms managing the ink flow. Here are some steps to identify and resolve the issue:
1. Understand the Problem
  • Is there an error message on the printer (e.g., “Cartridge problem,” “Supply system error,” or similar)?
  • Are prints blank, streaked, or uneven?
  • Is there any visible damage or leaking ink in the cartridge area?
2. Check the Ink Cartridges
  • Use Genuine HP Cartridges: Ensure that you are using authentic HP 952, 952XL, 956XL, or compatible ink cartridges.
  • Inspect Cartridges: Remove the cartridges and check for:
    • Damage to the plastic body or nozzles.
    • Expired cartridges (check the expiration date on the label).
  • Clean the Contacts: Use a lint-free cloth lightly moistened with distilled water to clean the electrical contacts on the cartridges and printer.
  • Reinstall the Cartridges: Properly reseat them in the printer.
3. Run a Diagnostic Test
  • From the printer’s control panel, navigate to Settings > Printer Maintenance > Print Quality Tools.
  • Run the Clean Printhead or Align Printhead tools.
  • Print a test page to evaluate print quality.
4. Inspect the Printhead
  • Clogs: If print quality issues persist, the printhead may be clogged. Use the printer's cleaning tools multiple times.
  • Manual Cleaning: If automated tools don’t resolve the issue, clean the printhead manually using distilled water and a lint-free cloth.
  • Reseat or Replace the Printhead:
    • Open the printhead latch and remove the printhead.
    • Reseat it firmly or replace it if damaged.
5. Perform a Printer Reset
  • Turn off the printer and unplug it from the power source.
  • Wait for 60 seconds, then plug it back in and turn it on.
  • Check if the issue persists.
6. Update FirmwareUpdate the firmware on an HP printer
  • Ensure the printer firmware is up to date. You can update it via the HP Smart app or from the printer’s control panel.
7. Check for Internal Issues
  • Look for any ink leaks or blockages inside the printer.
  • Clean the area where the cartridges and printhead sit.
Refer to this document: HP OfficeJet Pro 8720 All-in-One Printer series User manual
HP Printers - An 'Ink System Failure,' 'System Supply Problem' or 'Supply System Problem' Error Disp...
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
A_Gayathri
HP Support Community Administrator.
