- HP Community
- Printers
- problems with HP OfficeJet Pro 6978
04-15-2020 02:26 PM
My Office Jet Pro 6978 will not print items sent to it. I get a message of "there is a problem with the printer or print system. Turn the printer off then on; If you continue to get this message, contact HP. Ox6100004a
04-18-2020 09:22 AM
@jmorlock Welcome to HP Community!
I understand there is paper jam error although there isn't any paper jammed,
Don't worry as I'll be glad to help you, although, to provide an accurate solution, I'll need a few more details to dissect your concern:
Did you check if there is any paper stuck inside the printer, such as the ADF or the ink cartridge access area?
Have you attempted to clean the paper feed rollers?
Are you able to move the carriage freely?
In the meantime, please follow the below steps:
Step 1: Clear jammed paper from the input tray, ink cartridge access area and/or the automatic document feeder.
Step 2: Make sure the carriage can move freely
Make sure the carriage moves freely across the width of the printer.
Step 3: Clean the paper feed rollers
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Clean the rollers inside the printer, and then try to print again.
Gather the following materials:
A lint-free cloth
Distilled, filtered, or bottled water (tap water might damage the printer)
Click here for more details and step by step instructions.
HP OfficeJet Pro 6900 Printers - 'Carriage Jam' Error
HP OfficeJet Pro 6900 Printers - 'Printer Failure' '0x610000f6' or '0x61xxxxxx' Error
Keep us posted,
If you would like to thank us for our efforts to help you,
Give us a virtual high-five by clicking the 'Thumbs Up' icon below, followed by clicking on the "Accept as solution" on this post,
Have a great day!
05-01-2020 08:56 AM
Thank you for the update.
In that case, I would suggest you contact our phone support and check for the support option.
Here is how you can get in touch with phone support.
1)Click on this link - www.hp.com/contacthp/
2)Select the product type.
3)Enter the serial number of your device or select let HP detect your product option.
4)Select the country from the drop-down.
5)You should see the HP phone support number or Chat option listed.
Have a nice day!!
