every print comes out does not match with orignal picture. i have tried  cleaing cartrages  but still same output.
is there any soloution this situation?
3 REPLIES 3
@ayyaz1
Welcome to HP forums, I see that you are getting print quality issues.
Print a Print Quality Diagnostic page.
  1. Press and hold the Start Copy Color button  on the printer control panel for 3 seconds to print a Print Quality Diagnostic page.
    Example of a Print Quality Diagnostic page
  2. Review the Cyan, Magenta, Yellow, and Black boxes, checking for missing colors, fading, and white lines.
    • If the color blocks do not show white lines, and are not faded or missing, the printer is working correctly. Check for image resolution problems, application errors, or other issues that might affect the printout.
If it prints fine, then follow the below steps:
  1. In the software application you are trying to print from, click File, and then click Print.
    The Print window opens.
  2. Open the Properties dialog box.
    Depending on the software application, the button might be Properties, Options, Printer Setup, Printer, or Preferences.
  3. Depending on your print job, you might consider modifying the following settings:
    • Paper Type: If you are printing on photo paper, select the type of photo paper you are attempting to print on.
    • Print Quality: If you are dissatisfied with the quality of your printouts, increase the print quality. Select the Best mode.
If that does not print fine, clean the printheads
  1. Open or search for the HP folder in your list of installed software applications, click the folder for your printer, and then click the name of your printer.
    HP Printer Assistant opens.
  2. On the HP Printer Assistant window, click Maintain Your Printer.
  3. Click the Device Services tab, and then click Clean Ink Cartridges.
    A Print Quality Diagnostic page prints.
You can refer to this HP document for more assistance:- Click here
Let me know how it goes.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
i cleaned printing head with warn water it worked.
printing quality improved
@ayyaz1
Thanks for the reply.
I appreciate your time and effort.
Good to know that the issue is resolved.
Feel free to contact us in future if you need any assistance.
Please mark the public post as an accepted solution so that it benefits several others
Cheers.
Sandytechy20
I am an HP Employee
