Webcam Not Working? Advanced Fixes for HP Notebooks! Click here to view the instructions!
Common problems for Battery
I had the same problem and chanding the AC charger fixed the problem
i was having the same problem with my Hp Envy this morning after reading all the suggested solutions, i still could not come out with anything out of curiosity i decided to checked the charging pin for me to found out that the pin inside was bent not properly aligned. i took a fitting metal  and straighten the pin inside and it started charging well again.
pls try it it works for me.
