Windows 11 Support Center. -
- HP Community
- Printers
- Printer Ink Cartridges & Print Quality
- Re: Smart Tank 555 Print Quality Issue
11-29-2025 12:51 PM - edited 11-29-2025 12:52 PM
I've had the HP Smart Tank 555 for 2 1/2 years. The ink that came with the printer is barely used. The print quality is now terrible. I've tried all the maintenance routines multiple times to try and improve the quality, but nothing has had any effect. It looks like the only option is to buy new print heads. Can they really need changing already, when I have only used about 30% of the original black ink and 10% of the colour?
Solved! Go to Solution.
12-01-2025 07:47 AM
Hi @Wldy,
Thank you for posting your query. I will be glad to help you.
I understand you are experiencing print quality issues with your HP Smart Tank 555 despite having only used a small portion of the ink. There are several factors that might contribute to the degradation in print quality, even if the ink consumption is low. Here are some possibilities and solutions:
Printhead Condition:
- Over time, printheads can become clogged or otherwise compromised even if they haven’t been used extensively. Environmental factors such as temperature and humidity, as well as infrequent use, can cause drying or clogging of ink in the printhead nozzles.
Maintenance Routines:
- Although you've tried maintenance routines, sometimes repeated intensive cleaning cycles or a manual printhead cleaning, if available, can be more effective.
Storage Conditions:
- Ensure the printer and ink have been stored in an environment within the recommended temperature and humidity range to minimize the risk of ink drying out.
Firmware Updates:
- Verify if there are any firmware updates https://support.hp.com/us-en available for your printer that might help optimize its performance.
I hope this helps.
Take care and have an amazing day!
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Jerry_57
HP Support
I'm an HP Employee.
If this reply helped resolve your issue, please select the Accept as Solution as it helps others in the community quickly find the answer they’re looking for.
And if you found this reply helpful, clicking Yes below is a great way to let us know we’re providing the support you need, as it encourages us to keep improving and sharing helpful guidance.
12-01-2025 07:47 AM
Hi @Wldy,
Storage Conditions:
Firmware Updates:
I hope this helps.
Jerry_57
HP Support
I'm an HP Employee.
12-05-2025 11:19 AM
Hi @Wldy,
Thank you for your response.
We have sent a private message. Please check and follow the steps.
To access your private messages, simply click the private message icon on the upper right corner of your HP Support Community profile, next to your profile and send a private message to me with the serial number, because we value your privacy.
Jerry_57
HP Support
I'm an HP Employee.
