Mac OS X 10.6 Snow Leopard and older
I have an all in one pic 2175 that won't power up. When I turn it on, only the screen blinks. Nothing else happens.  I have tried the unplug and plug back in which did not work.  It makes no sound and ink cartridges do not move.  When I had it turned off, I manually moved the cartridges to the center so that I could remove them.  Still, nothing more than a blinking screen.
1 REPLY 1
@Bee5324
Let's try to reset the Printer here:
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Also, try connecting the Printer to a different wall outlet directly.
Try a firmware update: https://support.hp.com/us-en/document/ish_1776648-1643972-16
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
