Windows 11 Support Center. -
- HP Community
- Printers
- 7510 printer recognize usb connection NOT wifi
09-19-2016 12:12 PM
I'm using printer with USB not wifi. I cannot find the way to make it READY, it shows offline. I've looked for settings but it seems all are related to WIFI
The printer is showing up as my default on my laptop.
Solved! Go to Solution.
09-20-2016 10:25 AM
Hi @Jpryseski,
Thank you for stopping by the HP Support Forums! 🙂 I see your HP Photosmart 7510 is showing as 'Offline'. You are using the Windows 7 Operating system with a USB connection.
Please continue troubleshooting here: Printer is Offline (Windows)
What are the results? Are you now able to print to your PS 7510?
Please let me know the outcome. If this resolves the issue please let others know by marking this post as "Accept as Solution". To simply say thanks, please click the "Thumbs Up" up button. If you require further assistance let me know and I will gladly do all I can to help.
I work on behalf of HP
Click the “Kudos Thumbs Up" to the left of the reply button to say “Thanks” for helping!
09-20-2016 10:25 AM
Hi @Jpryseski,
