Windows 11 Support Center. -
- HP Community
- Printers
- ADF is not detecting paper load. No beep sound
03-15-2023 04:40 PM
Laserjet Pro MFP M127fw - ADF tray was giving paper jam error. Cleaned out the try and rollers with damp cloth according to instruction on this site. Still getting the same error.
Loaded 1 sheet of paper in the ADF and no sound made by scanner. Unplugged printer USB and Power Cord from Back, and wall socket. Waited 3 mins, held the power button down for 30 seconds and plugged back in.
Now error on compute is saying - "The scanner Automatic Document Feeder (ADF) does not contain any pages. Insert the pages to be scanned into the ADF and try again. "
The pages are in the ADF - still no beep from printer when loading the paper into the ADF.
03-16-2023 12:17 PM
Hello @Salman127 ,
Welcome to the HP Support Community!
Press this lever down, then a message should appear in the display, something like this "Original is inserted".
If no message appears, then the sensor is defective. The sensor must then be replaced by a printer technician.
Andr-1611
If my post resolved your problem please mark this post as an "Accepted Solution".
Or click on the YES button to reply that the response was helpful and/or to say “Thank You”.
I'm not an employee of HP, I'm as volunteer here.
Inquiries via private messages (PM) cannot be answered.
