Windows 11 Support Center. -
- HP Community
- Printers
- Attention Required with no problem - HP officejet 3830
12-26-2020 03:01 PM - edited 12-26-2020 03:02 PM
HP officejet 3830 will not print from my Dell laptop with Windows 10, connected via network.
The "User Intervention" status remains despite no problems and HP Smart software stating that the printer is "ready."
I have tried uninstall / reinstall of printer, software and drivers, updates, removing from ISP network and reinstall, and only thing that works for a single document is to turn off and on computer, then sometimes I get one document to print. After the one document prints, then the user attention error comes back.
Scan to computer and copy functions work.
Solved! Go to Solution.
12-29-2020 08:37 AM
Hi @cmc53,
I'd like to help with the printer connectivity issue.
Use HP Print and Scan Doctor to check connectivity
Download a special version of HP Print and Scan Doctor specifically created to help with printer offline conditions.
- Download HP Print and Scan Doctor.
- Run HPPSdr.exe from the download location on your computer.
- Once HP Print and Scan Doctor opens, click Start, and then select your printer.
- If your printer in not in the list, turn it off and on, and then click Retry.
- If there is a connection problem, follow the instructions in HP Print and Scan Doctor.
- If a screen prompts you to turn on printer updates, click Yes.
- If a screen prompts you to make your printer the default printer, click Yes.
Set a manual IP-
To set a manual IP and try the steps below -
--->Touch on the wifi icon ((i)) on the printer, and take down the IP address
--->Open a web browser (ex Chrome or Mozilla) and type in the printer's IP
--->then go to network ---> general ---> network protocols ---> select IPV4 only-->apply
--->go to wireless ---> wireless 802.11---> select manual ip ---> apply
--->Enter 8.8.8.8 for the first DNS and 8.8.4.4 for the second DNS.
--->then go to settings on the main ews page --> power management ---> select sleep mode to max 15min
Connect the printer to TCP/IP port
a. Click Start/Devices and Printers. Right-click on your HP Printer. Select Printer Properties. Select the Ports tab at the top.
b. Select Add Port. Select Standard TCP/IP Port. Select New Port.
c. Follow the Add Port Wizard. Under Printer Name or IP Address, . Example: 192.168.1.15. The IP address will be copied under Port Name.
d. Select Next and Finish the Wizard.
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
12-29-2020 08:37 AM
Hi @cmc53,
Set a manual IP-
12-31-2020 04:50 PM - edited 01-04-2021 10:01 AM
Print and scan doctor tried, does not work.
Adding the port as a Standard TCP/IP port did work. Specifically your suggestion:
Fir information to users: Both of my Dell computers with windows 10 had default selected the HP printer to a WSD Port, this may be due to the use of an HP 7740 at office. It has also been noted that the computers will sometimes default back to the WSD port and the user attention required warning comes back. When this occurs, the port setting needs to be set to Standard TCP/IP Port again.
01-04-2021 06:14 AM
I am glad the issue is resolved.
If you need further assistance feel free to reach out to us.
Have a great day ahead!
Please click “Accepted Solution” on my public post if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
