I have a 3755 deskjet with the power, paper, and web lights all blinking and the printer will no work. I've tried unplugging it several times. Help!!
1 REPLY 1
Hi @petewakelam,
Welcome to the HP Support Community
I'd like to help!
I understand you are facing the blinking light issue.
Try the below suggestions -
 Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
 Try updating the printer's firmware -HP Printers - Updating or Upgrading Printer Firmware
Also, try the relevant steps in the document -Blinking Lights
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution.
Click the “Yes" on the bottom right to say “Thanks” for helping
