HP Smart Tank 7301 All-in-One
This is easily the worst printer I have ever owned. It is flimsy and the lid has broken multiple times. It probably does not work more than it actually works, constantly getting paper jams, dropping off the wifi and any number of other issues that it can think of so as not to have to print anything. It is a piece of rubbish, please do not buy.
1 REPLY 1
@VesuviousX, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
Hi there, we’re truly sorry to hear about your frustrating experience with the HP Smart Tank 7301 😞. That definitely shouldn’t be happening, and we understand how upsetting it can be when your printer just won’t cooperate 😩.
We’d really like to help turn this around for you. Could you please let us know the specific issues you're currently facing? We're here to support you every step of the way.
If my response helped, please mark it as an Accepted Solution! It helps others and spreads support. 💙 Also, tapping "Yes" on "Was this reply helpful?" makes a big difference! Thanks! 😊
Regards,
Garp_Senchau
I am an HP Employee
