To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
HP OfficeJet Pro 8025e All-in-One Printer
Error message: Problem with printer or printer system.  HP3A044C Office jet pro 8020
1 REPLY 1
@DaleinaZ, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
If you receive an error message indicating "Problem with printer or printer system," it typically points to a general issue that might need a thorough troubleshooting process. Here are some steps to help resolve this error for the HP OfficeJet Pro 8020 printer:
1. Reset the Printer
Resetting the printer can resolve many system errors.
  1. With the printer turned on , disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait for 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
  5. Turn on the printer to complete the reset.
HP recommends plugging the printer directly into a wall outlet.
2. Check for Paper Jams
Paper jams can trigger system errors:
  • Open the front door, and then lift the ink cartridge access door.
     Opening the front door, and then lifting the ink cartridge access door
  • Wait until the carriage stops moving.
  • With the printer turned on , disconnect the power cord to avoid injuries.
  • Move the carriage to the far left and far right and remove any jammed or torn pieces of paper.
  • Reconnect the power cord, and then turn on the printer.
3. Clean the Paper Feed Rollers
Dust and debris can affect the paper feed mechanism, causing errors.
  • Turn off the printer and disconnect the power cord.
  • Open the front door and lift the ink cartridge access door.
  • Lightly dampen a lint-free cloth with distilled or filtered water, and gently clean the rollers.
  • Allow the rollers to dry completely (approximately 10 minutes).
  • Reconnect the power cord and turn on your printer.
Cleaning the rollers
4. Service the Printer
If none of the above steps resolve the issue, you may need to service your HP product.
Also, you may refer to this guide: HP Printers - An 'Ink System Failure,' 'System Supply Problem' or 'Supply System Problem' Error Disp...
I hope this helps.
Please feel free to reply here if you have any questions or if you need further clarification on any of the steps.
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
Garp_Senchau
I am an HP Employee
