Windows 11 Support Center. -
- HP Community
- Printers
- Error, "Photo Tray Problem" tried solution on screen, loud s...
11-30-2018 04:38 PM
Error, "Photo Tray Problem" won't print anything...tried the 3 soulutions, no luck.
Solved! Go to Solution.
12-04-2018 06:56 PM
Do visit our HP Forums and drop us a message anytime you need help
Thank you 😊
KrazyToad
I Am An HP Employee
12-03-2018 05:01 PM
Welcome to HP Forums. This is a great place to get support, find answers and tips.
I have gone through your Post and would like to help
Please ensure the photo tray is closed properly and nothing obstructing it
Then perform a printer reset
(1) Turn the printer on, if it is not already on.
(2) Wait until the printer is idle and silent before you continue.
(3) With the printer turned on, disconnect the power cord from the rear of the printer.
(4) Unplug the power cord from the wall outlet.
(5) Wait at least 60 seconds.
(6) Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
(7) Reconnect the power cord to the rear of the printer.
(8) Turn on the printer, if it does not automatically turn on.
The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
Wait until the warm-up period finishes and your printer is idle and silent before you proceed
Let me know how it goes
Thank you 😊
If the information I've provided was helpful, give us some reinforcement by clicking the "Solution Accepted" on this Post and it will also help other community members with similar issue.
KrazyToad
I Am An HP Employee
12-03-2018 05:49 PM
I tried the step two of the three solutions. It did not work for me...have to use a power strip... may be why it did not work. Solution three to reset default did not seem possible because the screen goes immediately to Error mode and therefore is not available to go through steps. My daughter tried go through steps in spurts between pushing the OK button (you can see normal screen VERY briefly) and the printer finding the problem and changing the screen back to "Effor" mode. Took quite a few times to complete one "try"...didn't work...may not have "meant anything" to the printer when tried like that. Breaks my heart to see it flashing. I love my printer.
12-04-2018 01:36 PM
Thanks for keeping me posted
I have sent you a private message with the next course of action
Please check your private message icon on the upper right corner of your HP Forums profile.
Next to your profile Name, you should see a little blue envelope
Thank you
KrazyToad
I Am An HP Employee
12-04-2018 03:16 PM
Thank you, Krazy Toad for all your help! I will get my daughter to help me with the next step you mentioned, she is more familiar with computers, etc. than I am. NIce to know there is help out there for my wonderful HP printer...and me!
