HP Officejet Pro 8600 Plus e-All-in-One Printer - N911g
Anytime I’m not using my printer on a daily basis and haven’t used it in a week or so, it always goes into some kind of sleep mode. I thought I should be able to touch the screen to wake it up, but that doesn’t work. The power button is pulsating and does nothing when I press it. I have to literally unplug it to restart it and then it’ll work for another week, give or take. Does anyone know a fix or do I just need to get away from HP all together, because it’s getting pretty **bleep** aggravating, not being able to speak to anyone in customer service!
1 REPLY 1
Hi @Bcal76,
Welcome to the HP Support Community
I understand you are facing a sleep mode issue with your HP Officejet Pro 8600 Plus E-All-In-One Printer - N911g. Not to worry I will help you to get a resolution to resolve the issue.
To assist better:
  • How is your printer connected to your PC?
  • Was there any recent update on the printer prior to the issue?
While you respond to that, Let's perform a power drain:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till warm-up period finishes and the printer is idle
Update the printer firmware
  • Click here to download and install the latest printer firmware from your product
  • Click here to know different methods of updating printer firmware.
If the issue persists, then we can try setting up the printer on Static IP ( If Printer is connected to your PC via WI-Fi only)
To set a manual IP and try the steps below -
--->Touch on the wifi icon ((i)) on the printer, and take down the IP address
--->Open a web browser (ex Chrome or Mozilla) and type in the printer's IP
--->then go to network ---> general ---> network protocols ---> select IPV4 only-->apply
--->go to wireless ---> wireless 802.11---> select manual ip ---> apply
--->Enter 8.8.8.8 for the first DNS and 8.8.4.4 for the second DNS.
--->then go to settings on the main ews page --> power management ---> select sleep mode to max 15min
You may refer to this document to know more about sleep mode: HP Printers - What is Sleep Mode?
ANAND_ANDY
I am an HP Employee
