HP 4632 error code OX83C0000A. Won't print. tried to power off then back on. Error code remains
3 REPLIES 3
Hi @ltrcunite
Welcome to the HP Support Community
I understand you are getting an error message  on your printer. Not to worry I will help you to get a resolution to resolve the issue.
Let's perform a power drain:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till warm-up period finishes and the printer is idle
Update the printer firmware
Click here to download and install the latest printer firmware from your product
Click here to know different methods of updating printer firmware.
Hope this helps! Keep me posted for further assistance.
Sneha_01- HP support
Thank you for your help. With your advice, I was able to print what was in the que. Unfortunately, the screen now looks like a tv that its way out. The top half is squiggly lines, the bottom half is the progress bar and the "cancel" button. Please help.
Hi @ltrcunite
I'm sending out a private message to assist you with the next course of action. In order to access your private messages, click the private message icon on the upper right corner of your HP Support Community profile, next to your profile Name.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Rachel571
HP Support
