Windows 11 Support Center. -
- HP Community
- Printers
- Re: HP Color Laser jet Pro MFP M281CDW- "Supply Problem"
11-05-2020 02:25 PM
All was working fine until on printer display pop for upgrade and I chose to do it, right after that start getting "Supply Problem" error and won't print. Automatic diagnosis said "Print queue issue is not fixed" but printer display shows "Supply Problem". Did that software upgrade now protecting for me to use cheaper brand Toner? I even put a brand new set of Toners and the same issue. Always use aftermarket toner and no issue.
Need immediate help,
I have chosen to buy compatible aftermarket toner in lieu of spending ridiculous prices for genuine
HP Toner. I got this error after HP update some software on the printer how to get around it.
I already have done the hard reset and installed newer firmware.
If somebody can please help me with this situation I would really appreciate it. Otherwise, I will never use hp product at all. Since my warranty expired I cannot even talk to a live person about this kind of issue is really a joke!
Please help ASAP. Needs to print asap.
Solved! Go to Solution.
11-05-2020 06:10 PM
Thanks to Andy_p2 for his steps, I had struggled some but here are my steps, may help someone, since HP will not support or live answer their customer. Since HP is the culprit here by updating the firmware to block all users who use after-market toners, I believe. I downgrade firmware driver with this version and it worked. HP_LaserJet_Pro_M280_M281_Printer_series_20200612
Worked:
Steps:
- on the printer, go into the printer's Setup | Service | LaserJet Update | Manage Updates
- set Allow Downgrade = yes, Allow Updates = yes
- on the pc, locate and download (HP_LaserJet_Pro_M280_M281_Printer_series_20200612) and run
- Point that to your printer, mine took few times since my printer connected wifi.
- After downgrade
- set Allow Updates = no (so the firmware doesn't auto-update and break compatibility again)
11-05-2020 06:10 PM
Worked:
Steps:
- After downgrade
11-06-2020 12:41 AM
I am having a very similar issue but it’s made worse because I’m also having the Service Error 49 crash loop that occurs shortly after the printer boots up. I was able to complete a factory reset and it appears to be more stable as long as I don’t connect to a wireless network. Every time I do that it crashes within a few seconds. I like the idea of rolling back the new firmware update but I cannot find the file for 20200612. This is so frustrating!
11-06-2020 02:21 AM
@JWK21, Welcome to the HP Support Community!
There is no option to downgrade the printer firmware.
Kindly follow the steps mentioned in this document to resolve this issue - Troubleshooting 49.XXXX Errors
Have a great day!
KUMAR0307
I am an HP Employee
11-06-2020 08:46 AM
This item is not "Solved" as of 6 November 2020. I accepted the update on my printer and it has the same "Supply Problem" and is stuck in an endless loop with a Error 79 now rebooting my printer before I can do anything to try to fix it. Extremely frustrating, HP!
11-06-2020 09:48 AM - edited 11-06-2020 09:50 AM
@Kumar0307 - my mistake on the error code: I am having issues with a 79 Service Error and frankly NONE of the fixes found online have done anything to fix the issue on my M281cdw.
I accepted the firmware update and that started the crash/restart loop immediately. I was able to reset to factory settings (which even took several attempts because it would crash/restart before I could). This seemed to help a bit as it appeared to be more stable, albeit with the supply issue error. Unfortunately, the problem persists when I connect to a wifi network OR plug an ethernet cable in as the crash/restart loop would start within seconds.
At this point I have a useless paperweight all because the firmware update was accepted. This is a horrible business practice for HP to brick my printer and NOT support resolution of the issue.
I understand that I have one or two ink cartridges that need to be replaced with genuine HP ink to avoid the supply issue error, but I have no confidence that the crash/reboot issue will not persist. Why would I dump $200 more into this when I am not sure that it will work? I might as well just buy a new printer that I know will work and cut my losses. Time to look at other brands, I guess because this is horrible from HP.
11-06-2020
03:48 PM
- last edited on
11-06-2020
06:00 PM
by
RodrigoB
For anyone who cannot find the link to the old firmware, I just got off the phone with HP tech support and got the link. Here you guys go: [content removed.]
