Windows 11 Support Center. -
- HP Community
- Printers
- HP DeskJet 1112 will not print using Chrome. Will print usin...
04-26-2019 08:01 AM
HP DeskJet 1112 will not print from Chrome. Destination keeps spinning. The printer will print test pages and from Microsoft Edge. I have tried everything short of re-installing Chrome. This happened on another printer I purchased and I returned that one only to have the same problem on this simple, USB plug in printer. I am sure others have had the same experience. I cannot be unique with this Chrome problem. Any help is apprieciated.
04-27-2019 04:22 PM
Welcome to the HP Support Community!
I recommend you follow the below steps and check if it helps.
To print from the Chrome browser, install HP Print for Chrome from the Chrome Web Store.
Open the Chrome browser, and then go to HP Print for Chrome (in English).
HP Print for Chrome app window opens.
Click ADD TO CHROME, and then follow the on-screen instructions.
The HP Print for Chrome window opens.
Close the window, and then continue to the next step.
Step 3: Print with HP Print for Chrome
Print documents, images, webpages, and emails from apps such as Google Docs, Photos, Mail, or Drive on the Chrome browser using the HP Print for Chrome app.
Print documents or photos saved in Files, Google Docs, Drive, or Photos.
From the Chrome browser, open the document or image you want to print.
Click the Print icon
The Print window opens.
Under Destination, click the Change button.
The Select a destination window opens.
Under Print Destinations, select your printer.
Change any print settings if necessary, and then click Print.
Print an email from services such as Gmail, Outlook, or Yahoo.
From the Chrome browser, open the email you want to print.
Print a webpage from Chrome.
From the Chrome browser, open the webpage you want to print.
Click the Chrome menu icon
, and then select Print from the drop-down menu.
Let me know how it goes and you have a great day!
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
The_Fossette
I am an HP Employee
