HP DeskJet 2823e All-in-One Printer
macOS 13.0 Ventura
I recently changed my Wifi provider and since then my printer is unable to be connected to a network. Along with that, i have racetrack numbers showing that printer is busy. Could you help me with troubleshooting this issue?
1 REPLY 1
Possibly these are the "racetrack numbers?
envy error codes
Error_CodesDescription
E0Unusable_cartridge
E1Paper_size_mismatch_error
E2Sensor/Paper_length_mismatch_error
E3Ink_carriage_stall
E4Paper_jam
E5Scanner_failure
E6General_printer_error
E9Update_error
one or  more of the following videos can help with connecting to the internet,
The below is all know about your Deskjet: 2823.  Hope I am not oversharing!
Watch the reset video or perform the steps. After resetting, you generally have 2 hours to complete the setup. Decide if you want to connect the printer to the router or to print directly to the printer and bypass the router.
Many HP and other OEM printers have problems with the router when the router has two bands and both bands have the same name (SSID). Log into the modem and rename one of the bands. Alternately, contact your ISP and have them rename a band.
Or simply use Wi-Fi direct (but read note below about Instant Ink).
If English is not your native language or if you wish to get additional information not covered below, then use the HP and Microsoft support assistants. The latest HPSA supports 36 languages and can be downloaded here. Microsoft's AI assistant is in the latest Windows 10 and 11 releases and there are instructions here on how to enable the AI. Microsoft's AI assistant (Copilot) has a microphone button and supports natural language processing.
Do not call any phone numbers shown in any of the videos or revealed by a Bing or Google search. You may need to reset your printer.
Disconnecting the USB cable may still leave the printer in the wired or Wi-Fi mode. Connecting an ethernet cable may still leave the printer in Wi-Fi mode. The Wi-Fi reset is used to put Wi-Fi printers into setup mode. Some resets are simple and others require a video to understand. Factory resets cannot be revealed in this forum. To do a factory reset of your printer, you must contact HP.
Click here for world-wide contact info
Wi-Fi reset instructions and videos (if any) are shown below. Generally you have 2 hours to connect your printer after performing the Wi-Fi reset. Note that a reset video may show a slightly different model than yours. Do not call any phone numbers revealed in any video or site.
Microsoft's Copilot may have more recent videos.
Watch this video to see how to reset your printer: 2800.
The steps below are Wi-Fi only and do not perform a factory reset.
Microsoft's Copilot may provide alternate solutions.
Steps: Our moderator can help:
Wi-Fi connection
Ideally, your Wi-Fi printer should connect to the modem or router. If your network has multiple boosters / repeaters, it is possible the printer may connect randomly to any of the units. The router needs to provide the same IP address on every connection. This rarely happens with random connects. An alternate Wi-Fi connection is Wi-Fi direct. Your laptop or smartphone prints directly to the printer and does not go through the router. Note that if you signed up for instant ink or internet printing your printer must also be online through the router. Do not call any phone number revealed in any video or site.
This video shows how to connect to the router: 2800 2810
Wi-Fi Direct can be used to avoid configuring the router. Watch this: 2800 2810 2842
Wi-Fi Direct is explained on page 11 of the User Manual, this Wi-Fi setup avoids configuring the router.
A simple connection to the router can be done by using the WPS pushbutton method. This is explained on page 11 in this User Manual.
HP updates software periodically. Downloads shown below may be old. You should always visit the Software and Download page to look for new releases. You may need to select an operating system (OS) first. If windows 11 is missing then use 10. You can go as far back as Windows 7, 64bit to get missing drivers. After selecting the OS click the blue Open all button to view all downloads.
Full function printer drivers can be downloaded here: 2800
Full function software for scanning can be downloaded here: 2800
You can find all of the software here. You should select the OS and then look for the phrase "Open All" and click that. 2800
Documents
All documents are available at the below HP site. The user and reference manuals show how to get status reports and analyze error indicators on printer that have no control panel.
All HP manuals are here: 2810
Support Videos - Parts - Disassembly
HP has a YouTube site and there are a number of video in English and other languages. Typically unboxing, clearing paper jams, and cartridge problems. You may also find instructional disassembly videos from other users.
Printer problems could be cleared by one or more of these HP YouTube videos 2800
Printer Reference
One or more printer reference is listed below. Typically your printer may be part of a series and use the same software and manual. The exact spec may be different.
Specifications for your system: 2800 2810e 2842e 2820e 2852e 2878 2855 2823e
Let me know if a problem
