HP Deskjet 2852E, the power light constantly blinking and will not print.
1 REPLY 1
Hi @AmandaB60,
I'd be glad to help you!
The printer is processing a job. To cancel the job, press the Cancel button (X)
You may also try a power reset -
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Also, try updating the printer's firmware Click here
You may also refer to blinking lights for more information.
Hope this helps! Keep me posted for further assistance
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-HP Support Community Moderator
