HP deskjet 6400
I noticed a solid amber light at first in the area that the paper comes out from. I restarted the printer as it displayed as offline.
On restart, there was a solid white line instead (not blinking).
I have tried unplugging for several minutes and holding the power button for >30 secs then restarting but after the initial green light while starting up, it returns to this solid white light.
I also changed the cartridges and paper just in case.
Also,  Hp smart was malfunctioning so i reset it. After which, i can no longer re-add my printer as it is "offline"
Any ideas? Any help would be appreciated.
1 REPLY 1
@Steffi-V
Welcome to the HP support community.
I understand that you are getting a printer offline error, I am glad to assist you.
Follow the steps mentioned in this HP document to fix the issue:- Click here
Keep me posted.
If this helps, please mark the public post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
