Windows 11 Support Center. -
- HP Community
- Printers
- HP Envy 7640 goes to sleep and won't wake up (requires power...
12-01-2020 04:44 PM
Ever since the HP driver issue with MacOS catalina, which forced me to uninstall and reinstall new HP drivers my Envy 7640 powers off after a few minutes and will not respond to its power button or to print requests. I have to unplug it to make it work again. It is hardwired to my network switch, is using DHCP to get an IP address, and has the latest firmware. Everything works as before when it is awake. None of the procedures offered here work. Auto-off is disabled since the printer is connected to a wired network. The HP support site is useless since the printer is out of warranty. I use instant ink, but I will not be coming back if HP abandons me here.
Solved! Go to Solution.
12-02-2020 03:23 AM
Yo have to go to settings in tool and factory reset, then reschedule the time to shut down 👍.
12-01-2020 07:23 PM
Never have I ever experienced the dissatisfaction with a tech site designed to assist users. Disappointing. Same problem - printer shuts off - no reason given. I have to walk into another room, unplug the printer , plug it in again and wait for the miracle to happen.
