Windows 11 Support Center. -
- HP Community
- Printers
- HP Envy 7800 won't print 2 sided flip long edge
07-24-2020 12:57 PM
I have retired my old HP Office jet and an Epson printer - both removed from Windows 10 via control panel. I have tried to install a newly purchased HP Envy Photo 7800 Series (7858). HP Smart says its 'Ready' but when you invoke 'Print' or 'Photos' it sends you on and endless search for drivers it apparently can't find; but Scan works.
Windows 10 recognizes it and it prints from documents, but the duplex printing only prints 'flip short edge' despite 'long edge' being selected. Both my Smart Phone and Chromebook print successfully. I've seen other posts that say - 'Solved' for a similar problem, but entail involved modifications to registry etc. The printer should install and print on Windows 10 laptops without heroic measures. I'd like to know if there a straight forward method to correct the drivers - (HP Smart doesn't work); alternative is to return printer.
07-27-2020 09:50 AM
Uninstall and reinstall it the HP Smart App.
If the issue persists, try these steps:
Let's run the HP Print and Scan Doctor:
Use this link for details on using the HP Print and Scan doctor: https://hp.care/2JyaC93
If the issue still persists, let's do a root uninstall and reinstall of the software:
Unplug any USB cable, if any, before doing this.
1.) In Windows, search for and open Programs and features
2.) Select your HP Printer
3.) Select Uninstall
4.) In Windows, search for and open Devices and printers
5.) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose 'Delete' or 'Remove Device'
6.) Open up the run command with the "Windows key + R" key combo.
7.) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe” and “/s”)
8.) Click on the "Drivers" tab
9.) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10.) Select Ok
11.) Select Apply and Ok on the Print Server Properties windows
12.) Close Devices and Printers
13.) Open up the run command with the "Windows key + R" key combo.
14.) Type c:/programdata and click Ok. Go to Hewlett Packard folder, remove any printer related folders & files.
15.) Restart the computer.
Once done, please download and install the software from here:
https://support.hp.com/in-en/drivers
Let me know if this helps.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thanks!
Have a great day!
I am an HP Employee
