A few days ago, the printer was working just fine, not until I decided to use it again and realized that it won't work. Only four of the buttons light up but the power button won't. I've tried holding the power button and pressing the cancel button but it seems like nothing works. 459412585_3581610235388937_8469681862715430027_n.jpg459883198_531861856031739_2137014061448872692_n.jpg
1 REPLY 1
Hi @Cez4,
Welcome to the HP Support Community
I understand you are facing an issue with your HP Product. Not to worry I will help you to get a resolution to resolve the issue.
To assist better:
  • May I have the exact name of the model of the product? Refer to this document for steps to find the product details. Do not share your personal information such as serial, phone number, email ID, etc.
Could you please elaborate in detail?
I hope this helps! Keep me posted.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution.
A_Gayathri
HP Support Community Administrator.
