HP OfficeJet Pro 8710
Hi, I can't get my HP OfficeJet Pro 8710 to print on 110lb cardstock.  I have tried uninstalling and reinstalling the printer and related software.  I have also updated the software on the print itself. Additionally, I have tried setting the printer to "index card" and "plain paper, thick".  None of these options make a difference.  The printer continues to print 1/2 to 3/4 of the page.
Can anyone help me get it to work?
3 REPLIES 3
@mucky1217, Welcome to HP Support Community!
Are you able to make copies on the cardstock paper?
If yes, follow the steps below:
Update the printer firmware
HP regularly releases new printer firmware versions with product enhancements or issue fixes. Depending on your printer, apps on the printer control panel might also receive updates. Update firmware and apps on a regular basis to make sure you are getting the most out of your printer. Click here to download and run the update. Refer to this document for more help.
Create a Custom Paper Size
Refer to this document HP Printers - Creating Custom Paper Sizes for assistance.
Try printing. If the issue persists, continue troubleshooting.
Install Windows Built-in Printer Driver
Install your HP printer without any software using the drivers built into the Windows operating system. Refer to this link for help.
Try printing.
Let me know the outcome.
Cheers 🙂
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
TEJ1602
I am an HP Employee
I did all of those things and none of them fixed the problem.  I was trying to print on 110lb paper, which is within the printing specs of the printer.  I could only get it to print on much lighter cardstock (65lb).  Even that was a little dicey and a few pages didn't print correctly.
@mucky1217
That's unfortunate. Since the issue seems to be unresolved you can try our other support options for further assistance.
Follow the steps below:
1) Click on this link - https://support.hp.com/us-en/contact-hp
2) Select your product type below.
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Select the appropriate option based on your preference.
6) Fill the web-form and proceed further.
Thank you.
TEJ1602
I am an HP Employee
