Windows 11 Support Center. -
- HP Community
- Printers
- HP OfficeJet Pro 8720 Printer Offline Issue
09-05-2017 02:25 PM
Thanks. I will try phone support.
No offense, but I am very disappointed that the software doesn't work. Having to do all of these workarounds is frustrating. The printer should just work.
I don't have a USB cable for my laptop (Macbook pro, USB3), haven't used a USB cable to print since the 1990s! 🙂
I'll reply back after phone support so share what I learn
09-05-2017 03:44 PM
Hi,
I tried to get phone support and it said that my system was out of warranty as it was one year old.
I ordered the produyct on 9/3/16, it arrived on 9/4/16 and I set it up 9/15/16, so it is under warranty (certainly when I filed the original request).
I expect that HP will honor the warranty. Can you give me some guidance on how to do that?
09-06-2017 06:24 AM
Thanks for the reply @JF14,
I have escalated your concern to HP’s Support Team in your region to have it reviewed for available options, if any.
You should be contacted within 4 business days (Excluding holidays & Weekends).
Response times may vary by region.
Please send a Private Message, if you aren’t contacted within 4-5 business days.
Chimney_83
I am an HP Employee
- « Previous
- 1
- 2
- Next »
